A conduit message could not be sent to one or more I/O Modules asynchronously. An PBB operation could not be completed as a result. The system may be low on resources or busy.
Undo and redo the configuration after the current activities complete including IOB reboot or the backup MM reboot. If the problem persists, contact Extreme customer support with the output of "show tech".
Debug-Summary
Asynchronous message send to %slot% failed for action %action% due to error %ret%
| Name | Type |
| slot | uInt32 |
| action | String |
| ret | String |
